BBChopper- I'm probably not seeing the whole picture. How/why do I need to be careful with silicone?That sucks, but be careful with the silicone! I hate using silicone with and “O” Ring!!:2thumbs:
Both of mine have an o ring type gasket. Be careful putting it with the silicone. The silicone extract (left over) falls into the case ( I was pissed when I found all that shit haging in my primarry). Good “o” ring gaskets are the best!! Lubed with some silicone lube or light oil. They work!!! Or replace them!!:2thumbs:BBChopper, I dont have an o ring on the inspection cover. the actual outer primary cover has an o ring. is that what you are talking about.
Irish, technically you should use a new gasket with a little silicone around the edge of the flange that the gasket and cover sits/bolts to.
Wow, I need info on Dat!Throw away those orings and sponge for the inspection cover and replace it with one gasket.Thats what my previous dealer did cuz of my complaining oil leaks.Now no more leaks.
