ncmustang
I changed the fluid in my primary and my clutch started slipping in fifth and sixth gear if you get on it. When this started I took the primary cover off, made sure the clutch basket nut was still tight, and put 20/50 weight in the primary but it is still slipping like it did before. When I put this fluid in I started noticing a little bit of fluid on the bottom of the primary case like it was too thin and seeps out. Is there a different weight that would help either of these problems. It didn't slip till I changed the fluid but I am not sure what was in there in the first place.
