Primary capacity
nine lives
On my 06 mastiff, I noticed on the primary under the inspection cover it lists the oil cap. as 1 1/2 quarts My service manual say's 32oz I have always put 32oz's in any primarys on Harleys, anyone explain this?
lee
many of the primaries had the wrong thing stamped on it - mine's the same
A
adamthisis
Guest
I know the manual says 32oz but if you pull the outer primary cover you will get about another 8-10oz out of it. So if you just drain the oil put 32oz but if you pull the cover put a little more. I know mine says 1.5quarts on the bottom of the inspection cover, I think that is the maximum it can hold.:cheers:
