Pops out of 1st??
danosrs
Three times now is the last month after starting the bike in neutral and then when I release the clutch I've had it slip out of 1st gear??? I downshift and it seems OK, never has it done this while normal riding?? This has got me worried since I'm planning on going to Sturgis this July and plan on 4k plus miles?? any suggestions on what happening?
RCAdd1ct
JAFO
If it is like my HD trans the dogs on the gears are worn.
Mine wore out from partial crash shifting due to a faulty hydraulic clutch actuator. I had to replace the second and third gears ( at separate times).
Might be a good ideal drain the fluid and see what shavings come out.
danosrs
Just thinking maybe before I get crazy with this thing I should do a shifter paw adjustment? Anyone ever done this??
M
micky nettle
Guest
Jumping
I had the same happen to me, It was all of a sudden. Thought the worst, Adjusted the shifter slightly and no other probs 2 years.......
danosrs
Shifter Pawl? so your saying it would only jump out of 1st some times and all other gears were OK? Do you remember how you adjusted it??
Tks!!
danosrs
Ok I put the bike in 3rd gear and disconnected the shift linkage and see the shift lever from the tranny moves about 1/8th inch forward and only about 1/16th aft? think this might be the problem??
danosrs
Ok, I used a "C" shaped 11/16th wrench to loosen the lock nut and turned the adjustment 1/4" screw 1/8th turn out and now the lever is same movement forward and aft. First check ride was good, guess I will have to ride more to see if it happens again.
