Ok, probably the last installment. Recapping, I had a rough running engine between 2000 and 3000 RPMS with severe decel popping any time I let off the throttle even slightly. the bike felt like it was running out of gas when trying to cruise below 30 (2300 to 2800 RPM). The throttle was very sensitive and difficult to control
I followed the S&S recommendation on jetting and put a 60 in the main jet air bleed. My mechanic put a screen on the intermediate jet to atomize the fuel. We then added lollipops to increase back pressure and increase exhaust gas speed. We did not remove the intermediate bowl vent plug, as recommended however.
Results
The throttle is very responsive but smooth through the entire range. Cruise in the 2000 to 3000 RPM range is smooth and comfortable, jerking is gone. Decel popping is dramatically reduced, vibration has reduced significantly. With V&H 2 inch, 2 into 2 short pipes and a cone air cleaner, the decel popping won’t go away, based on my research, but the bike runs great, and the barking is minimal. There is a felt increase in torque but a Dyno is not in my current budget.
thank you all for the guidance. You are all the best.
