please help! WP on my 04 DT
JWAUGH
this is the ehc board on my 04 chopper dt but it doesn't match the instructions on my WP kit 374!!! it says I should have a black one with one plug and a bunch of grounds coming out of it. what is the proper instructions to replace this ehc with the WP kit?
that is an updated EHC. Instructions should be the same.
There are about 25-30 black ground wires all in that one plug harness.
Rottweiler
http://www.bigdogbiker.com/forums/a...ease-help-wp-my-04-dt-img_20130904_170259.jpg
It is a newer style EHC that has two plug that someone installed a adapter board on it to work with the single plug style for 2004. I have the same thing on my 2004 chopper. Question what problems did you have before you went Wire plus? My bike works when it wants to? Other times the emergency flasher come on. Still trying to figure out if it is a wiring problem or EHC? :bang: Any info. would be nice. Thanks
TimNY
YIKES / Is that what it looks like under a BDM Chopper seat .
I'm sure glad I wired my bike myself - Simple ThunderHeart Chopper wireing kit.
Looks just like my old ehc. The majority of the wires will still be attached to the plug that goes in the top of the ehc. Its not a tough job, but it is time consuming. Its a bit easier if you clip all the black grounds first, then tackle the remaining wires....jmo.
