Passenger peg offsets vs V&H 2-1 exhaust
dba777
I installed Vance & Hines 2-1 exhaust on 08 Ridgeback, now passenger right peg wont drop down due to lack of clearance with the exhaust. Could someone recommend offsets that would fit the bike?
I have located kuryakyn offsets, but not sure if they will fit.
Adjustable Lockable Offsets | Küryakyn
aspen874
Big Dog made a adapter for the 2-1 pipe, you may try BDM performance, Bikers Dream or some of the Big Dog dealers around you. They were 100.00 last time I checked. Also check with Lena at Strokers
wyatt580
I have the adapter on a 08 ridge with the v/h 2 into 1 and they work just fine....I just figured you would know what x2 ment go figure!!!
MIAMIVICE
Now i know. will call up BDM
Good Luck! I've been in the Hunt for the adapters since Jan... I went to Kansas while they were still open and the parts guy was able to find 1 adapter which he sold to me for $20bucks...Contacted them a month ago and they are trying to find a machinist to make more under contract...Apparently they included the adapters if you bought the V & H from BDM, which was about $700+..:(
dba777
Here is the solution.
Issue:
After installing Vance & Hines 2-1 Big Radius pipes Part Number: 193-000031-01 on 2008-10 Big Dog Ridgeback, passenger right peg drop down and will be touching the pipe.
Solution:
This system will require a set of passenger clevis adaptors. Its available through Big Dog Performance products http://www.bdmperformanceproducts.com
Clevis Adaptor Kit Part Number: 163-000041-01
Link to adapters: http://www.bdmperformanceproducts.c...pegs-and-grips/mounts-clevises/163-000041-01/
