I'm going to figure out which way my screw turns on any clutch assembly.
1. If I know where my adjust screw is, I am going to hold the clutch lever and have a screwdriver/allen on that adj-bolt: are my positions with both hands.
2. I already have the slack out of the lever until I feel resistance. I am going to turn the adj-bolt in or out.
a. IN = My lever begins to move back to the perch lever assembly.
b. OUT = My lever begins to move to the hand grip.
c. Perch = My movement with the adjust screw is to follow the lever back to the perch, not the grip.
3. I just found my direction is to move the lever back to the perch or move IN until it the adj-bolt stops. Even if it's reversed, meaning, if I move the adj-bolt OUT and the lever move back to the perch, I found the correct direction is follow the lever back to the perch.
