Old Ignition Switch Wires???
seatmaker
After installing the 3 wire switch necessary when going to the Wire Plus, what do you do with the 2 wires from the factory switch? Jake says (You will need to run 3 power wires for the 3 position (12 or 14 gauge min.) and 2 wires for the two position switch from under the tank to the module mounting location for the new switch.) That lost me. Do they hook to anything or do you just ignore them? Wondering if that has anything to do with my speedo acting up.
bdmridgeback
Low Down Chop Shop
Jake says:
(You will need to run 3 power wires for the 3 position switch OR 2 wires for the two position switch. These get run from under the tank (near coil) to the module mounting location.)
seatmaker
I'm calling it quits, yanking the speedo off and gonna make a cool housing for a GPS unit.
Throttle Jockey
Don't Look at my Member!
You could prolly do that and have speedometer but what about your tach?? Did you take your speedo apart and make sure the connections weren't broke?
TJ
