Staffy
D
Can you tell which Kind of oil it is - Engine, Tranny or Brake? (Viscosity - color). This could give you some indication as where to look.
On my bikes (RSD) I think the rear brake line that runs underneath and between the tranny and primary - if the same is the case with you - DO NOT RULE THAT OUT - (although - you would have known by now cause of the loss of power and movement in the brake pedal)
good luck.
good luck.
