Oil line leaks
HD uses steel tubes to it's oil filter housing. These tubes slide up into the housing. Special design orings are used. Bought new orings, installed, one leaked again.
Took my trusty fits anything tool out of the toolbox, cotton rope, unwound a strand long enough to wrap around the tube; soaked it with E6000 or Amazing Goop Glue; shoved the tube's nut up the housing; squishing and closing off the oil path down the tube.
Been a year or so since. Haven't heard of the nephew calling out a leak at the tubes.
Go to 'oil filter w/ mount' See 11,12, 7 and 8.
Disassembled all the oil lines. Put silicone sealant on the thread and tightened up. Hope that will work. The bike stayed idle for a month. Had to drain oil. The guys who serviced the bike before stripped the oil plug. Ordered from Harley Evo primary, same.
Changed the voltage regulator and the circuit breakers as there was no charge.
If anyone needs:
1. Plug. https://www.jpcycles.com/product/drag-specialties-magnetic-primary-drain-plug?sku_id=10230269 (same as Harley)
2. Regulator. https://www.amazon.ae/dp/B07DYLZLX8?ref=ppx_yo2ov_dt_b_fed_asin_title
3. Circuit breaker. https://www.amazon.ae/dp/B0CS94QS9F?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
or https://www.ebay.com/itm/396049890997
