P pantjw New Member Jun 26, 2014 #1 Oil seems to be leaking out of the bottom of the crank case out of a plug leaks more when the oil is warm but still leaves a small spot even when it's cold any help stopping this would be great
Guillaume Active Member Jun 26, 2014 #2 Maybe you have to drain your oil take the plug out and see if there is washer on and clean it
W woodbutcher Mr. Old Fart member #145 Staff member Jun 26, 2014 #4 if you are talking about the crankcase drain, i believe that is a pipe thread plug. use some yellow teflon tape, and don't over-tighten it.
