LA_Dog
Go Fast, Go Faster
hi all- need some guidance on what to check. 2001 BD ProSport, 107 motor, baker 6, 3700 miles on it. I have a bit of an oil leak while bike is running. After I park the bike, it leaves a decent 4" spread puddle and then stops. does not keep leaking when sitting. the "puddle" is from the accumulated leaking oil while I'm riding.
The drip is coming off the very bottom of primary case directly in front of the drive sprocket, and in looking up behind there i can see the oil originating from behind the primary and farther up, directly in front of the engine drive sprocket. Does not look to be coming off of engine, and it does look like engine oil vs primary oil, but I guess it could be primary oil (I did not put the fluids in last - just bought it and it was recently serviced).
I know it is not coming from any breathers on the engine because I though that was the cause originally and I routed the breather lines to the right rear of bike for now.
Thanks in advance-
Thanks in advance-
