Wildthing
Got Life?
I got a new oil leak the other day.
My cylinder gaskets are getting squeezed out at
the bottom of the front cylinder base
where it bolts onto the bottom engine case.
Oil has started to leak out of the squeezed gasket.
What causes this?
Is this a common problem?
Is there enough room to get the front cylinder off
with the piston down or does the motor need to pulled
to replace those gaskets?
Thanks for any help or advice on this
Ron
What causes this?
Ron
Cheap insurance called bolt stretch
