Oil Coolers
WB Cycles
whats the cost on the dual coolers???
BDM100-00499 / POLISHED OIL COOLER KIT - $234.00 each
Fits:
"07-08 K-9
07 CHOPPER
07 PITBULL
05-06 - ALL MODELS
2004 PITBULL
2004-08 RIDGEBACK
2008 MUTT"
Other versions available for different bikes not listed. :2thumbs:
slowrower
2007 Mastiff
I was going to make the mod to do this? They have it??
No mod needed .. just buy two of them and you have all thats needed plus a spare line!! I can feel them get hot riding on the highway and when stopped at a light so they are giving or should I say taking heat away from the oil. According to the S&S Manual for some cam setups they require at least one.
emcclary
I have a dual oil cooler setup on my K9 but I have it setup with an automatic thermostat bypass for the cooler weather. Here in NJ it will bypass the cooler until the oil hits a certain temp then switch over to flow through the units. It is my local dealers setup not the big dog one.
reloaderbmg
OLD DOG
Would like to see pics.
From BDM website:
"This BDM oil cooler is the perfect ingredient to prolonging the longevity of your motor by reducing oil-operating temperatures up to 30 degrees!"
Does this work by simply rerouting oil out through the tubes which gets cooled by air then redirected through the engine?
I mean, they look really cool but is there official testing that proves they do the job?
Thanks!
PROFLYER
SWOLE
I like that look too! Nelson, what's a package deal for either setup gonna run? Can you source the one emc has?
dogvet
Banned
Excellent point! A thermostat is a must, keeps the oil temp in a good operating range. I believe that most thermostatically controlled oil coolers don't allow oil through the cooler till oil temp is 180 degrees.
emcclary
Main reason I went with it I instead of the big dog version. I also like the dual tubes running the frame instead of the short fat single tube BD uses.
dogvet
Banned
You have a temperature gage? Just curoius what kind of oil temps you run with that set up.
emcclary
Havent put one on it yet to see. One of those future mods I will get to at some point. I know it doesnt do much standing still except give you extra oil but it certainly cant hurt either. I figure the BD setup is a u shaped tube within the larger single tube around 10" long. My setup runs two seperate tubes and they are both around 14" long without the crossover tube. I may have to see about setting up the temp gage for the ride to Myrtle Beach next month it would be a good test for it.
