Oil Cooler ????
WB Cycles
The cooler comes with a long and a short line (feed and return). You use the short line from one to connect the two coolers and the other long line to run back to the filter. You end up with an extra short line in the end.
BBChopper
Supports 2 Disabled Vets
Yea that was this first thing I did was the cooler and a pressure gauge. You can tell by the pressure when it’s getting hot. I am changing to Amzoil this week!!! Florida is a hot bitch!!:eek: :2thumbs:
reloaderbmg
OLD DOG
im making up a two cooler set up but went with, y,s in the hoses to split the system , that way oil goes throuh both cooler at half the flow rate [slower the oil flow the more heat you can remove] & the back pressure in the return is lower so the pump does not have to work so hard!
WB Cycles
Great idea !
