My 2003 ss107 BDM blows oil out the crank case breather, (that's located behind the back jug) when I hot rod it a lot. My breather has a hose going to the crankcase. When I ride it staying under 3 1/2 grand no problems. Any ideas??
Add oil only to the halfway spot bMy 2003 ss107 BDM blows oil out the crank case breather, (that's located behind the back jug) when I hot rod it a lot. My breather has a hose going to the crankcase. When I ride it staying under 3 1/2 grand no problems. Any ideas??
yes; overfill is my guess tooI think sometimes they may drip or spit oil once in a while. Never heard or seen one that throws oil all over the engine. Maybe it's over full?
See if this analogy works for you. Throw a tablespoon full of liquid soap in a baggie. Add water. Zip it closed. Now, shake the shit out of it.My 2003 blows oil out the crank case breather...when I hot rod it
Next day we go out and clean up the garage floor directly under that hose, and the bag of soapy water is just laying there with the bubbles gone. Go over there and pickup the bag. Hold each end at the zip line corners. Hold it out and look at the level in the bag. Tilt the bag like a sea-saw...When I ride it staying under 3 1/2 grand no problems. Any ideas??
