OEM Prime Clutch
Im looking for pics of the oem primo clutch on a 03 big dog chop. Changing clutch pack and just want to make sure i have everthing installed correctly.. Any help would be great
VT Chad
This is from the manual:
Replace the clutch plates starting with the thick steel plate first (.120), then alternate fiber (.90) then thin steel (.045). follow until all drive and fiber plates have been used. The first and last plates should be thick steel. Always place the steels into the clutch hub with the flat side in first.
Replace the pressure plate, diaphragm spring, spring retainer (bevel side in) four shoulder nuts and retainer plates.
Hope this helps, mine is apart so I couldn't send a pic.
