O ring chunks in primary mystery...
LuLu
05 Pitbull I just purchased and first time taking it apart. I found some pieces of O ring inside the Primary case when I took it apart. They were small flexible rubber type chunks. Where in the heck could these have come from? Sorry. I didn't take any pics. But it seemed kinda odd to me. Everything seems ok other than the fact that I need a new pressure plate... It almost looked like they would form a 1" circle. I only found 3 pieces about 1/4 inch long...
francoblay1
The Spaniard
I am not 100% sure.... but, by the dimensions you are quoting, I would say it comes from the starter shaft?
Did you check the Primary Inspection Cover?
Was it low in oil? leaks?
liferider
Looking forward to retirement
I agree, take primary case off. While it's off replace, starter O-ring and main case inner & outer O rings & gaskets
LuLu
No oil leaks. Inspection cover seal was fine. I will just start taking it apart as y'all suggested and go from there.
I wonder if it was pieces from the outter primary cover 0-ring along the top that maybe got pinched the last time it was off.
