Noise coming from Baker open primary
mleach72
Hey guys, my Baker open primary is starting to make a lot of noise. I believe it is coming from the front sprocket. When I rock the belt back and forth, I get a clunking sound. Any ideas? Do I have a bearing going bad or something?
knothead
Second Chance Customs
I'm wondering if your clutch disc fingers are wore bad enough to cause the sound your hearing...I have had MastiffDaves baker off his bike 2 times working on it...he didnt have a clunking sound it was more of a clinking sound if that make sense...what I found was the clutch disc (fibers not the steels) had enough wear on the ears that it was making a clinking sound...I put new clutch in it and it fixed the problem
mleach72
Knot, I'm pretty sure it's coming from the front sprocket. I didn't install it or ever have it apart, so I'm not sure what all is involved. Everything seems OK at the moment. I don't notice any difference except for the noise. It kinda sounds like every other open primary right now. The Baker was always quiet. That what I liked about it.
knothead
Might be possible the front sprocket might have come loose but I doubt that...there is nothing there besides the sprocket sliding on the crank and bolting up...only bearing there is the crank bearing...everything on the baker open primary is a tight machine fit I do know that...you got my wheels spinning trying to remember what all is there on the baker now...and your right a baker open primary are damn near silent
