No where to turn! Sick dog
PZNIVYCHOPPER
I will update as soon as I hopfully figure it out. Or ride with my thumb on the run switch all day! Just kidding, well maybe not.
Ray
Deepest sympathy to you for your sister passing my friend,,, I found a wire crimp that still looked good but was still not as good as it should been on mine ,, fixed and repaired it ,, It was just about the time I was getting frustrated with it and maybe talking to it a little when I found my issue,,it was right in front of me all the time, finally got it to act up,, it had just about got the best of me, but persistance and these guys on the forum here payed off,
Ray
hayseed
My condolences....... I would consider wire around the ehc and run a hot lead with a toggle switch and run it around for a couple of weeks or three... If you still have an issue it's dirty tank/fuel (maybe from sitting so long) or its electrical on the ignition / crank sensor or coil breaking down when hot... If you don't have any issues your ehc is on its way out and consider rewire. There are posts here that show you hot to hot wire... Good luck
Roaddawg
our prayers are with you and your sister. As for you electrical problem, I had a similar issue with my '05 Chopper. I could ride 100 miles and it might sputter and die, but hitting the start button would bring it to life, other times it might only be 15 miles. My problem turned out to be a small wire on the tach board that had broken. It was so short it would normally lay where it needed to be for the bike to run, but the right bump or vibration would disconnect it temporarily and the bike would shut off.
Just something to check.
BadBrad
2005 Pitbull
Good God Almighty guys! It would be a shorter post if you listed what you thought wasn't wrong with it. I think Dennis' advice will get you narrowed down. First, determine which red light is on the EHC when the bike shuts down and list anything else that shuts down, i.e. lights.
