no start
vettehog
typical white person
hey guy's how do you tell which is bad the thunder heart or th ehc .
the bike got wet in the shop due to frozen water pipe back in jan .
took it out today and the the ehc had this white crap on it and when the key is turned on it blinks once then goes off .
any thoughs .
Escobar
It may be the EHC, the thunderheart modual should be potted/sealed internally to prevent water from getting in, however that was a recall that was implamented back in '04 which you profile shows to be so it may or may not be sealed, you can take it apart and see if it is. If not then you can fill it with an electric grease to keep water out in the future. As for the EHC, water may have gotten in the connector and is shorting it out, it sounds like you have a short somewhere, disconnect the connector and see if there's settled water between the pins.
vette,
The white thick milky looking stuff is dielectric grese when exposed to water.
Sounds like the EHC is tripping itself out due to a short in the electrical system.
Disconnect the battery and dry out all wire connectors and "everthing". Take the time to really check it out and ensure that everything is dried out really good!
Then re-dielectric grease all of the connectors and the 2 "D" connectors on the EHC and reinstall and retry.
Hopefully, no more issues after "all" of the water is removed from the system.
Good Luck! :2thumbs:
dead :cheers:
remove your ehc, clean it out real good. let it dry. then repack the dielectric grease and reinstall. Report back.
