now, that's a new one. :up:I just had something similar happen a week ago. Some how I got some water in the starter and the bearing rusted and froze up. wouldnt turn the motor over and battery load tested ok. pulled starter, sent to rebuild and am up and running like new.
does make a difference. :bang::bang:hehe dumbass, first make sure the clamp for the loadtest are on the right terminals...turn bike on was at 13, started it up below ten...bike started and the headlight came on...this bike is wiered...charging battery
Do you have any fault lites on the EHC. Look for a thread from Nighttrain on symptoms. He has some good suggestions to check when it quits on you. When it dies is it electrical or does it sound like it's running out of gas? Have you checked the gas cap vent?Battery stll low on load after charging..mut did start..ran down the road on the bike and died..waited for bout 5-10 minutes and start up..drove up and down the road in front of the house to get it to die again but no luck..thinking next it might be the ehc...mfg date on the ehc is 0438.
sux that it cant be checked after it dies..
it also not starting at start up...even then i can try a few time and leave it. then try again and starts, where the cam sensor on the 04heard some guys having cam sensors getting hot and dies.wont restart till sitting awhile.might try the search tool.
im going to drive it again up n down in front of the house and hope it dies...to tinker with it ir not i might take it to strokers dallasif the light was not coming on on your ignition (your first post) then it sounds like you have a problem with the module. Could just be a loose connection as the problem is intermittent.
ill have to ask the guy i got it from...but looks to be the orignal. its the black box. is the nose cone the piece below the air filterwhat ehc do you have? is it the one that came with the bike or the updated one?
Ahh the EHC... It's the only "black box" youd like to leave on the bottom of the ocean.... its the black box. is the nose cone the piece below the air filter
