no running lights
Horton 1
Hello everyone, I have no running and tag lights on a 03 bulldog, brake and turn signals work , any suggestions ?
Dakotabos
Check under rear fender and see if you see bare wires. If that's good check the right side of your frame and make sure the wires are not on bottom side of frame and damaged. If that's all good you have a bad ground I am betting. Most of the grounds are by your battery box.
My .02 cents:cheers:
good luck :2thumbs:
