No low beam
Before I put it away last year the low beams would switch to high around 3 minutes after I start my bike. I switch it back to low stayed on but switched back to high after a few minutes. I started it today low beams are not turning on . The connector looks good. I changed the bulb but still not working. Anyone else have this problem?
Kdub
In am having the same problem. Just replaced my bulb, then neither light worked. I finally got both of them working properly. Went out to ride and no light. High beam would turn on witht he switch, but if you switch to low beam there is nothing. Frustrated beyond belief.
Widerider
Not might be you problem, but I had similar issue with no Low-Beam for long time. Hi-Beam worked so I left it alone. Then one day leaving parking lot from local watering hole headlight housing fell off. Headlight mounting bolt just broke right off. I mention this because there was light electrical arc marks between triple tree and mounting bracket. After making repairs my low-beam was working. No Problems since.
Check your connections on the headlight harness you may not have a good connection , also if you switched the wires make sure you assembled the wires correctly
