Paul taylor
Yes the whole kit was new.
.Hi Paul, I'm not familiar with this kit but I read the manual Mr. Wright sent you on the other thread.08 and I just put the gen 1 rip kit on it bike ran and everything. I hit the stop button now I can’t get any power to the ignition module and this is a carb bike so the ignition wasn’t changed.
I think whats happening is the Off/Kill side is staying engaged. Did you try to run with the MPC Disconnected? My diagram shows 6 wires 4 on one side and 2 on the other. I think the module is meant to shut down the engine Not to provide power to the Ignition system. Do you have the diagram or instructions that came with the wire set you put in? What is the name/number of the set.Correct bike was running I hit the stop button now nothing it the ignition module. I did ring the power wire and ground out they are good. Everything on that pad works blinker,start, and the run button gives me 12v when I push the run button just behind the PCB like it should. I have taken to battery out thinking it also may reset the module with no luck. To not drive my self nuts I ran a jumper off the battery from ground and one from pos and touched the pins on the ignition module and got my red light. What I don’t see is how to test the power coming out of the momentary switch. My switch has 3 wires in one side and 4 on the other. The diagram that was sent to me had 3 in and 2 out so I am sure there has to be something a little different with the one I have. This bike is very sentimental to me as I lost my mom and she loved it but it has taken every ounce of energy to not drag it to the lake and throw it in. I have to keep walking away at this point because I keep doing the same checks that I can and know how to with the same result that don’t make sense.
Did you try to run it without the Momentary Pushbutton Converter plugged in . If not do it to help diagnose. look for the ignition light also while the MPC is disconnected.I didn’t get a diagram with the harness and trying to find one seems to be a big problem
So it worked before you cleaned up some wiring or did whatever you did? I'm a bit lost on the sequence.Yeah I have emailed someone there. So I took the momentary module off and put 12v to the wires until I seen the red light come on the module. My buddy had a momentary module but his had 4 wire in and 4 wires out so maybe that’s why the swap wouldn’t work I guess I will order one and see what happens.
