No brakelights
Nbtrble
I have see a couple of discussions regarding brakelights but I haven't seen any with my specifics.
I have a '02 Bulldog and have no brakelights (front or rear) also I only have one rear turn signal. I have checked the wiring under the fender and it all appears to be fine. I have also checked the wiring under the seat and nothing stricks me as wrong. Any ideas what may be wrong with it?
Thanks in advance,
Rodger
Thanks in advance,
Rodger
Do you have the BDM wiring diagram to help you through the electrical system?
If not, PM me with your email address and I'll be more than glad to send you it! :2thumbs:
dead :cheers:
BadBrad
2005 Pitbull
Sounds very similar to the issues Rocky had with her '03 Mastiff as the EHC began shutting down. Look well under the rear fender. Could be a ground short but no front or rear lights and no turn signal on one side sounds similar to EHC trouble.
mobsta
ok gotta go there,brake lights front or rear?do your turn signals work in the front?its probably not leds but take the one that works and put it on the other side to see if it works,just a thought:D
