Razorback25
I'm having problems with my brake lights when using either hand or foot control, they don't light up. The running lights and blinkers all work fine. My bike has LED's also. Something unique is, if I engage either foot or hand brake, then turn the ignition key on, they light up and after I let off and try to engage again, they don't work. I've checked the rear brake switch by shorting out the two wires, and still no brake light. I've noticed a small black box under the seat that lights up green when either blinker is on, but doesn't turn green when the either brake is applied unless the brake is engaged, then the key is turned on. I did just finish installing the foot extensions, and noticed the lights not working after bleeding the brakes. I'm not sure the brake lights were working before I installed the extensions as I didn't check, and have only rode once this year. We are supposed to get mid 70's this weekend, and gonna try and stretch out a little ride. Any help you guys can provide would be greatly appreciated. Thanks in advance
