Are they the same length as the other ones, including the ends?i don't get it got a new set of throttle & idle cables put them on they where loose adjusted them as much as I could but still loose any suggestions thanks
I should have checked but I did not check before I put them on the ones on there where not adjusted all the way the new ones are adjusted all the way and jest a little looseAre they the same length as the other ones, including the ends?
Yes all set up right must jest be not the right cables should not have to adjust them all the wayFirst thing to come on my mind is do they sit correctly inside the grips
