Twisted
Ok, I posted my "Redoing Stock Pegs with Worn out Rubber" thread in the General section and got some good feedback so I figured I'd post a how to write-up to show anyone interested how you can make use out of your stock pegs that have beat up rubber. And best part of all, its CHEAP!!!
So after much searching for the right size rubber band type foot peg rubber and coming up with nothing, I came up with the idea of looking into cutting up a plumbing Fernco fitting into rings. Heres how to do it...
First you need to find the right size connector, I found these at Lowe's and they are for a 1.25-1.5" pipe and fit the pegs perfectly, just make sure they don't have any embossed wording, these are plain, some may not be and would look like crap, these were under $4 each and you can get 3 bands from each...
So all you need is connector like this and a used peg, when I bought my bike the passenger pegs looked like this, if yours still have rubber you will have to pull, tear, or cut it off...
Here it is without the band clamps,you will use one band clamp and make sure you have some new razor blades...
