New pipe, resulting flat spot
Coolbreezin
Hello,
I have a '05 Big Dog Ridgeback (117ci & Super G carb). Years ago I added a K&N air filter and had no problems. Recently I swapped the factory pipe with a Paul Yaffe Drag Pipe. Now I have a flat spot at 3,000rpm and up. It just appears to level off and I produce no real hp or thrust. The low end gained a little though. Im still using the factory jet, a 31 I believe. What size jet do you recommend i go to? Or is that not the problem?
Also, when I decel at 2,100rpm, I get an odd chatter feeling through the whole bike as if Im rolling over the rutnuts in the emergency lane on the interstate. Could this be related to the air/fuel mix being off a bit? This is the first time Ive felt this on a v-twin.
Please advise what to do or where to go to find the fix.
Thank you.
Coolbreezin :flag:
Member of The Patriot Guard Riders.
Associated with The POW/MIA Foundation of Jacksonville.
Volunteer at City Mission Center – Jacksonville, FL
Brew
The chatter feeling sounds like a lose motor mount. Mine did that and I found my upper motor mount bolt lose... Check your motor mounts
Coolbreezin
Hey Brew,
Good call. I was passing time checking for anything that looked odd or was loose and sure enough, loose upper mount blot. Tightened her down, but havent done a test ride yet. Appreciate your time and knowledge...and thank you for serving our great country.
Coolbreezin :flag:
Http:\\BigBikeJaxSucks.com
Coolbreezin
Hey Pancakecircus,
Thank you for the video. It was interesting and educational. Ill do more searches online for info. On a side note, it would be nice to see that 3/4 liter Honda.
Coolbreezin :flag:
the Honda's been on the side all summer, i'll be getting back to it soon. I might start a build thread on Do the Ton or on TCU. Otherwise i'll post some more pics once i get back into it. lost a little motivation once i got the Big Dog.
good luck figuring out your flat spot, make sure to post the fix
