big orange
Just had an S&S 640 cam installed in my 07 K9, That is the best $$ I've spent on this bike!! It blew me away how much more power it has & the sound is wicked!!! Cam & rejetted carb. Now THIS is the way this dog should run!!:up:
Marv,got that also.
now bump the compression to at least 10.8-1 and hold on!
Marv, Can't you also put in a colder plug??if highest octane gas is used and still get detonation the options are to lower comp or retard ignition. IMO
i have mine set at 28 degrees at full advanced (3K rpm's)
with the 640 cam it really pulls hard into high rpm's. so with a good valve train, jim's rollers, travel limiters, triple wound springs set for the cam, i'm comfortable raising the limiter to 6500 using the dynatek 2KI ignition
Did you have anything else done to the engine?Just had an S&S 640 cam installed in my 07 K9, That is the best $$ I've spent on this bike!! It blew me away how much more power it has & the sound is wicked!!! Cam & rejetted carb. Now THIS is the way this dog should run!!:up:
Yeah I should specifiy "on a dyno". I know that when working on EFI in cars on a dyno we (my bud an engine builder) would swap out plugs for help with timing.
5-600 cam and install.What's the average cost on doing something like this?
