New air filter
Posted this once before and had some negative feedback. So I said f@@& u all and did it anyway . I do like the spiked filter but got sick of all the oil blow by. I like the new filter
The carb isn't jiving with the new filter starts sputtering at about 2600 rpm's until I roll into the throttle. Started dropping Down the main jet started at .74 and now I am sitting at .68. Intermediate is .31
francoblay1
The Spaniard
Don´t forget the Air bleed jet.... just saying.......
Oh, and get rid of the plug.... Bowl Vent Plug that is.
Going to look at it tonight. After much reading I am thinking the new gasket is blocking the bowl vent hole... Not sure if this what is causing it but it's a start. Then I will remove the bowl vent plug .
Removed the plug didn't have a chance to ride it yet. Pulled the primary vent bleed jet. Which is a .060 decided to install it and test it with the plug removed. If that doesn't fix it then I will go up on the bleed jet
