New Air filter K9< carb pipe problem ! Help please
S
Steve in UK
Guest
Hi, hope someone can be of help please ! I have just tried to fit a new airfilter to my K9 ( 2009 Carburettor model) the new spike airfilter fits ok, ( a few problems with choke, but will over come this.
My question is, what do i do with the pipe that goes to the back cylinder.
On photo No1 it shows the new filter and shows the black pipe, on photo No 3 this shows the back of the original airfilter conecter and where the pipe fits as standard.
What do i do with this pipe please, ? block it off ? drill out the new airfilter housing and put pipe in to take this ?
Any help would be very much apprecited .
Steve in uk
RCAdd1ct
JAFO
Steve in uk
Either extend the hose and add a small filter to it or add a fitting to the underside of the elbow.
Most people add another filter.
RCAdd1ct
JAFO
On another note. You need to support the filter on the outboard side of the carb. That extra weight out there will cause issues later.
S
Steve in UK
Guest
RC Addit
As in just leave pipe where it is with a small filter in end to stop crap getting in it ?
Sorry for idiot question !
How do i support the filter please ?
many thanks
RCAdd1ct
JAFO
RC Addit
many thanks
On my Harley I ran it to the bottom of the frame and hid a filter there.
It is the engine breather hose to let gasses that get by the rings escape.
It is an emission thing. Not sure how strict they are....might need to run it to the elbow to comply.
S
Steve in UK
Guest
RC
many many thanks, emissions here are not so much a problem, have found small filter, and found bracket to hold it, thank you very much..:2thumbs:
RCAdd1ct
JAFO
RC
Glad to hear it
Happy to help.
If I am not mistaken that hose goes to a one way valve. If it does, I would extend it from there if you need the hose longer for your new filter.
S
Steve in UK
Guest
RC and Carlos
Yes is one way valve, understand it all now,, many, many thanks for your help.
New Boots
Human
Remember what Little-Boo said
You need something like this
D&M Custom Cycle CARB SUPPORT BRACKET/ BREATHER KITS from TRICKED OUT CUSTOM CYCLES
If you run it without the support bracket you will have to replace the Intake gaskets over and over and over and over again. So get one.
Carlos :D
Here is an example of what you need – This stuff is everywhere so keep - looking if you don’t like these. :2thumbs:
Enrichner Knob and Cap
Just the thing for when you are using an aftermarket intake on your S&S™ Carb. Simply unscrew the stock enrichner and screw in our beautiful new unit complete with show chromed knob.
Choke Knob - EnrichnerKnob
Breathers with Puke Can
francoblay1
The Spaniard
Not an answer to your question but just my input about your new filter.... Lots of us, including myself, have had problems running this type of filter in the horizontal position as you have it in the photos.... If you run it in the vertical position you might find the Dog runs a lot better. Plenty discussed here in the forum on this matter.
S
Steve in UK
Guest
Kennybob & Francoblay , many thanks, very good advice, will get the choke (Enrichner) nob as was wondering how to sort that, many thanks . most apprecited.
One last question : i have a set of V&H radius pipes coming 2-2 from Bikers dream atlanta, they are sending me also the jets which are "This recommended jet kit will provide optimum performance out of your S&S G carburetor when installed with our Big Radius exhaust system. Kit includes .076 main jet and .031 intermediate jet." do these sound correct ?
many thanks
Germanbiker
Hi Steve,
the jets seem to be right.
But they more depend on your intake - are you running stock or K&N or the S&S Filter-setup?
I run a 34 / 78 in my XXXcarburetor together with a highly modified BDM air intake and open pipes.
Jochen
New Boots
Human
I’m sure when you called and ordered the pipes he ask you the elevation of your present location. If they recommend it I would go with it. Don’t forget to remove the Auxiliary Bowl Vent Plug #14
This page has good information and will help you a lot. They will send you the settings to start with (I think it’s a quarter turn difference)
S&S Cycle | Carb Quick Guide
One other thing no one ever talks about is the little blue o-ring that you might find in the bottom of your carb after you take it apart. (Found mine in the bottom of the bowl and had no clue where it went) Here is a picture of it. :flag::flag::flag:
http://bigdog.voices-inc.com/blue.pdf
Don’t forget to wipe the news pipes with alcohol as to remove all finger prints after insulation or they will burn into the new pipes forever.
Those are the same pipes I got and I slow way down around the law dogs house and cars – they are LOUD :2thumbs:
S
Steve in UK
Guest
Kenny Bob
you say " Don’t forget to remove the Auxiliary Bowl Vent Plug #14 "
I see it on the web page, but exactly what do i do with this please, is it just unscrew and leave out ?
thanks
S
Steve in UK
Guest
Kenny Bob
good tip , i would have just started it up ... had these pipes on my HD rocker C, thought they looked great , and yes real noisy ! good for annoying local residents !!!!
thanks , very much apprecited
S
Steve in UK
Guest
Jochen
I have standard filter at moment, but have a spike one to fit , which i like look of, Bikers dream says " i wouldnt use it, as bike will misfire" i read here that better pointed up rather than forward ..... so not quite so sure what to do ,, think i will fit pipes as they be here by weekend , then see if all runs ok , then if good try filter, if it runs crap, then put standard filter back on,,,
any advice on this set up would be most apprecited
