New 08 Pitbull Died 325 Miles
PitBully
Just motoring down the road felt like it ran out of gas but has plenty. All lighting and starter work but just will not kick over.
Any thoughts.
Thanks
narow37
Angry Southern White Man
check to make sure the white plug isn't in the bottom side of the gas cap. could also be that the terminals on the battery are loose. or the ground at the other end.
Nomad2day
Longhair Redneck Geek
Sounds like the crank sensor went south on you.....:rant:
If the bike turns over and does not fire up, it is a good bet anyway that it is the culprit...
Been there done that....
Neil
PitBully
No it's not fuel injected.... what is a introduction. Whatever it is I'll do it when it fixed.... I'll look at it tomorrow morning and it would be nice for check some simple things to start.
Vegas
I wouldn't be in the mood for an introduction either. You need to verify if you have fuel and spark. Take off the air cleaner and pump the throttle. Pull a plug wire and use a spark tester to check for spark. Or take it back to the dealer and let the warranty cover it.
