Need some help please
drbalazo
I have been struggling for some time here on my 2004 bulldog. I have the wire plus installed and had been running fine until I put a new battery. I doubt the battery caused this but it's too much coincidence. I think the SWITCH CONTROL MODULE may be problem but would like some confirmation from someone here that might know more than me here. The green LED light on the module does light up she I press the horn, hi/lo beam, on/off, turn signals but when I press the START button, it does not send any signal out to get spark in the spark plugs.
Any help would be appreciated. TIA
ringo
just to clarify, it cranks over fine but wont start immediately after a battery change?
francoblay1
The Spaniard
Did you miss a wire connection or break a smaller wire off the battery?
X2, I am not familiar with the 04 models but what Huw said... check all wires, lots of folks had similar problems and it ended up just being a crashed wire... worth to check b4 starting to go further in depth.
