Need info on electrical replacement parts
todd774
Being new to Big Dog electrics, I thought I'd pick some brains.
I have a 2004 Pit Bull w/ ridged frame & for the most part, stock harness.
I need a new (what I think is a start module. Part # BD4120-1 also says 0334 Appears to be a starter relay. Where do I find one & can I cross reference it to something else?
Also: Do to height restrictions, I think I can only fit a battery W/ 230cca. 5-1/8 High. #CYTX15L from Interstate Batteries. Not having the old one to reference, Will this be OK?
Any help would be greatly appreciated.
Thank you,
Todd K.
todd774
Update,
I got a Hold of Curtis (WildSteedWorx) the other day. The man was kind enough to call me & explain a few things about Big Dog electrical systems.
He said he might have good used starter module around somewhere but haven't heard back from him yet. I came away with the impression that this is a sophisticated electrical system that needs to be wired correctly. This wiring is hacked. parts of it were rewired with 16G wire with crimped butt connecters
all over it. This bike needs work. Curtis offered his help if I ever wanted to correct the bike to stock specs. The customer just asked for a battery, oil change & tune up & get him back on the road for the rest of the season. I spoke to S&S. The man on the tech line thought I would be alright with a 230 cca battery. I'm gonna put a remote starter button on the back of the starter & isolate the starter system. Is this the right way? I'm sure some will cringe reading this. I'll inform the customer what I learned & see what he wants to do in the future.
Everybody who took the time to input is very appreciated.
That's why I took the to update this thread. Thanks
Todd K.
BadDawg Bill
I'd rather put in a starter button on the coil cover connected to a relay. You can get a relay at any auto store for around $12 and it will work for a long time.
bearman
.....a starter button on the coil cover connected to a relay......will work for a long time.
But a slam button on the starter is for emergencys. And it will work when nothing else will. The problem is that if nothing else is working, it probably wont crank even if you can get it to spin over.
A Braille 2015 will also fit the 2004 Pitbull battery box and will provide ample cranking amps.
