Need Help
stephyarborough
I have a 06 big dog mastiff. Just got a whole new wiring harness with the fuse box. When trying to start with the starter button, it will not turn over. No power coming from the starter to the solenoid. You can jump it and it will crank. Any suggestions?
Also, no tach either.
pknowles
RETIRED
offhand, it sounds like a weak battery for
starters. have your battery checked.. what electronics did you use
stephyarborough
Meter an multimeter. Did find out right hand control pcb board is burnt. But I can't locate one on the web. Also want to get a new battery. What is the best kind? Thanks for the help!
Little-Boo
You can get one from BDM performance Parts at
153-000048-00 | BDM
Little pricey but they are not easy to come by. I have two extras that I will take to my grave with me if I don't ever use them but will not part with them. :D
Carlos :whoop:
