Need help Neutral light blinks in any gear
shawn27405
I installed a new HID Light dont know if that is thr problem but after that I noticed the neutral light stays on but blinks if I give it gas then its less noticeable anybody know what does could be I took the positive battery cable off for 15 min. To see if that would reset anything
Splitlog
Sounds like a issue at the other end check connection at trans.
Possible sending unit if connection is good
