Need Help - ID Clutch Diaphragm Spring
cousinaz
Hello All: Thank you, in advance, for your assistance. I am changing the primary chaincase oil in a relatively new-to-me 2000 Vintage Sport, with a 107 cu in TP engine. My manual states that the capacity is approximately 32 oz and that the oil level should be at the bottom of the clutch diaphragm spring. Is the diaphragm spring visible in the attached picture? Or, is it the same diameter as one of the visible components? Thank you. Dave
FrankBDPS
What oil are you using? Do not use synthetic with that clutch. It won't work. I use just plain old automatic transmission fluid. That is what Rivera calls for.
cousinaz
Thank you for the info. I used mineral-based, no synthetics, for all of the oil requirements. HD Formula+ for the primary and transmission; Motul 20W50 for the engine. Thanks, again.
