:iagree:Sounds like the battery took a dump on you for some reason. Charge up you batter and check the charging system. Check the battery voltage with the engine not running and fully charged, should have 12.8 volts or 13. something. Then start the engine and check the voltage with the engine running. You should get about 1/2 to 1 1/2 volts more on your meter which will indicate the charging system in doing what it should. You can also increase the rpm and see if the voltage increases also.
where is the vr circuit breaker or pic of one would be nice:iagree:
Plus I would check to see if the VR circuit breaker has popped since that would explain the battery not being charged up.
Dennis
:2thumbs:It's the little "box" directly above the LEDs on the EHC. There's two lugs on it each with a wire. The reset button is most likely on the side facing the EHC (the bottom).where is the vr circuit breaker or pic of one would be nice
