Just tore into the switch. Its shiny new in there with plenty of dieletric grease to keep conection... So it has to be something else but im out of options... Its not the wiring... Its not the battery... Its not the starter... Its not the ehc... Wtf is left??Not sure what the start button is doing but I'm glad you got the TH hooked up and going. Hopefully a new switch will help with starting.
Could be a bad ckt board in the switch. Had to change mine awhile back.Just tore into the switch. Its shiny new in there with plenty of dieletric grease to keep conection... So it has to be something else but im out of options... Its not the wiring... Its not the battery... Its not the starter... Its not the ehc... Wtf is left??
Sent from my LGL82VL using Tapatalk
The "start" button... Push it and you get a soft single click from the ehc... Hold it after a couple minutes itll startWhat button are you holding down for five minutes? In five minutes you should be up running,warmed up and ready to ride.
That's good news and an easy fix.Figured it out... Its the conection to my starter solenoid... I wiggle it and it fires right up... Now i need to figure oit if its just the recieving plug or the solenoid itself...
