Need help again...
drbalazo
I had starting problems with my dog and tried the heat gun on the ignition module and it died, so i bought a new thunder heart ignition, which seemed to fix the bike for about 2 weeks until today. I was on the way to work and the bike just died on me. Once it got cold, it started back up again and rode it for about 2 miles before it died again. I seriously doubt it would be the ignition module again, no? What else could i check now?
2004 bull dog
Dakotabos
Cam Sensor fails like that. Heats up break contact I chased my tail on my 2004 chopper to find out that SOB was bad
Little-Boo
Could be your Cam Sensor . I would also check the coil, provide you are running the stock coil. I use the two coil set up and when one went bad, the bike would miss. I would let it cool down and off we went for 2 or 3 miles and same shit again. I replaced both coils and wala not a problem since then.
Carlos :whoop:
drbalazo
Can it be bought at the local Harley shop? IF so, what cam sensor do i order for my 107 s&s engine?
Brew
A few members have bought from Harley, maybe one will chime in on which one works best...
