Most have the 107, but the 117 was an option that yearWhat different size motors did the put in the 2004 chopper??
The reason I ask is because I did this serial number search at sscycle and it says my motor is a 113. I was told it was a 107 is that normal ???.Most have the 107, but the 117 was an option that year
No, it's definitely not a 113. Only options are 107 and 117. What is your engine serial number?The reason I ask is because I did this serial number search at sscycle and it says my motor is a 113. I was told it was a 107 is that normal ???.
There is no way that is correct. Are you sure you punched the number in correctly? What is the second letter in your code? The first letter should be an "E". The next letter will be either a "C" or "E".So I’m reading this wrong ???
Ecoo659 I don’t even pick up the bike until tomorrow. I had the guy send me the number last night. Maybe he sent me the wrong numberThere is no way that is correct. Are you sure you punched the number in correctly? What is the second letter in your code? The first letter should be an "E". The next letter will be either a "C" or "E".
I’ll definitely be checking the ven and serial before I throw him some moneyEcoo659 I don’t even pick up the bike until tomorrow. I had the guy send me the number last night. Maybe he sent me the wrong number
First letters and capitals E then a lowercase cEcoo659 I don’t even pick up the bike until tomorrow. I had the guy send me the number last night. Maybe he sent me the wrong number
No I don’t think so. Looks like a custom build by that information.So I’m reading this wrong ???
What does the C stand for?There is no way that is correct. Are you sure you punched the number in correctly? What is the second letter in your code? The first letter should be an "E". The next letter will be either a "C" or "E".
So, is that good or bad lolNo I don’t think so. Looks like a custom build by that information.
Yeah, I think he got a number wrong. The C means it's a 4" bore motor. The 107 and 113 are both 4" bore, but the 113 wasn't available on a big dog. Recheck the number when you get it. You can always check the flywheel code. That will tell you for sure what engine it is.I’ll definitely be checking the ven and serial before I throw him some money
I would say that’s good. John Sachs would be the best person to give some insight to you. He’s the S&S guru. See if you can send him a messageSo, is that good or bad lol
ThanksI would say that’s good. John Sachs would be the best person to give some insight to you. He’s the S&S guru. See if you can send him a message
I can’t find his name to message himI would say that’s good. John Sachs would be the best person to give some insight to you. He’s the S&S guru. See if you can send him a message
Go to the search top right corner. Go to members. Type in John sachs. Should pop right upI can’t find his name to message him
OK I’ll wait until tomorrow when I make damn sure that the serial number I don’t wanna look like any more of an idiot then I do now if it’s wrong lolGo to the search top right corner. Go to members. Type in John sachs. Should pop right up
It's possible a previous owner swapped out the 107 for a 113. I'm not aware of a 113 coming from the factory on a big dog, but anything is possible.OK I’ll wait until tomorrow when I make damn sure that the serial number I don’t wanna look like any more of an idiot then I do now if it’s wrong lol
