My DOC's ESC install.
Rickman07
Definitely doesn't need a larger wire I'm going to have to say it's from cranking too long what should the starter be drawing in the first place maybe I
chubs
Does it need the next larger gauge wire? Or is it cranking too long? Or is your starter drawing more than it should?
What are the chances of the contacts inside the solenoid being a little arced up creating a "high joint" and heating up? Kind of like the electrical receptacle in the house that has loose wiring, that heats up and burns the house down. I'd guess that if ya were to touch the terminal bolt on the starter right after cranking it over , it'd be pretty warm. ( or, maybe not) :2cents::2cents:
Rickman07
Ever since I've join this forum I've been learning so much information it's all starting to connect the dots w the issues that I've had over the last 3 yrs nothing major until this yr w the diagnostics I've been exploring w the harnesses and the ehc:oldbang:
