Mutt gas tank 2008
BFB
Bad dog, no bisquit
Will a 2008 Mastiff tank(4.6gal) fit on the 2008 Mutt(3.8gal). I thought I saw somewhere that the mutt had a mastiff frame?
No, the Mutt tank is the same tank used on the Chopper and is 4 pt mount. The Mastiff tank is a 3 pt mounted tank. It'll fit if you want to cut off the mounts on the frame and weld on news ones to support the Mastiff tank.
BFB
Bad dog, no bisquit
Sounds like a good option. Much easier to re-work mounts then cutting a tank apart. Also makes it a summer project since I can ride while the new tank is out for paint.
