Mastiff / Mutt front end
joker9r
Does anyone know if the triples used on the Mutt are the same as the Mastiff? I'm debating doing a conversion to the Mastiff wheel and fender... I'm shooting for a wider front wheel and tire.
Thanks
joker9r
Found my answer.... Should fit, will just need to modify the fender brackets and change out the hubs I guess. I like the idea of a wider front tire such as the Mastiff and I'm hoping to score a deal on some Fat Daddy 50's from somewhere.
Little-Boo
If you need a stock set of trees I have one complete with bearings and all. I even have the upper tubes, no lower legs.
Carlos :whoop:
RubWhore
Asshole Extraordinaire
I did it and you haint got to change hubs or nuthin all you do is change fender brackets and fender even though a Bigdog has a unicke width on there front end..I posted pitchers on here somewhere of the conversion.
joker9r
Awesome! That was my initial thought but wasn't sure... Thanks RubWhore! :cheers:
