Yep, and my rear pegs are facing correctly so no issues at all!Mine were higher and new style, @Brandon Downey bought them from me and put on his mastiff with no issue
If you enlarge Franco’s pic, and rotate his peg mounts 180*, remove the riser, his peg would be back further and at the same hieght it is now without the riser.Franco has mounts that you have to use risers on to clear that exhaust.
I have both sets and that is how I know.
Paul.
Hi Pauly..If you enlarge Franco’s pic, and rotate his peg mounts 180*, remove the riser, his peg would be back further and at the same hieght it is now without the riser.
leave my pegs alone!!!
That is correct Kevin like i have said there are two different peg mounts.Hi Pauly..
Ive tried all angles but the peg still hits the pipes when in the riding position.
I'm working away at the moment so can not take pics of them as I have both of the mounts at home.
However these will work.
Paul.
That´s right. These are the ones I´ve got on my K9 also.You most likely have a set of these which won't work with your exhaust.
Paul.
These are the Clevis Brackets i have, but it sits too low.. Pegs hits the pipes..
I guessed that much... if you need the elevators just email Curtis ( @KaptinAmerika ), I posted the link earlier and it will take you to the webpage.These are the Clevis Brackets i have, but it sits too low.. Pegs hits the pipes..
Thanks, but ive already ordered a pair from Donna.. CheersI guessed that much... if you need the elevators just email Curtis ( @KaptinAmerika ), I posted the link earlier and it will take you to the webpage.
Cool! I didnt know Derek & Donna had them too... It always has been my understanding those elevators were made by Curtis!!Thanks, but ive already ordered a pair from Donna.. Cheers
