RubWhore
Asshole Extraordinaire
homo de yamas ??????Illegal Alien, huh? Ce = Yes..To both questions!
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
:2thumbs:
:2thumbs:
The crank sensor is located on the front of the motor.Thanks for the info. Where is the external ignition located at on my K-9? what would it take to replace the thunder heart ignition with a twin tec external ignition??
Sorry Brother!..... Eric's "Not Here" right now! :nono:homo de yamas ??????
Just like I just told the other guy.I had one of my "suction eric's" break off of my seat, Anyone know where I can get him?
rsntfr,Thanks for all the info and getting me up to speed... Sounds like ill be keeping the EHC to run the lights, etc but I need to install a MAP sensor so that I can wire up the Twin Tec ignition. HDLARRY, where did you buy the MAP sensor for your 05 Bulldog?? Is that a BDM or a HD part?? Thanks again.
Read Larry's post again, the map sensor comes with the S&S IST ignition system. If you are goint to install the Twin Tech ignition and it requires a map sensor they should provide you with one. The the S&S IST ignition system requires a Map Sensor and it comes with the kit.Thanks for all the info and getting me up to speed... Sounds like ill be keeping the EHC to run the lights, etc but I need to install a MAP sensor so that I can wire up the Twin Tec ignition. HDLARRY, where did you buy the MAP sensor for your 05 Bulldog?? Is that a BDM or a HD part?? Thanks again.
I was jus tring to shows you I could speak mexicanJust like I just told the other guy.
Sorry Brother Eric's not here presently! :nono:
Maybe try again later! :2thumbs:
Absents on Fridays has a price that has to be paid!...........
