NUKNUK
I'm in the middle of installing a XXX g-carb and g-manifold (part#16-2595) on my 05 ridgeback. I've read on here that you need to either keep the restrictor plates on or get a spacer kit to replace the plates for the XXX "e" carb and manifold. Well since I'm installing a "g" carb can I just remove the restrictor plates and mount the g-manifold directly to the heads without a spacer kit?? I've been trying to mount it with the restrictor plates on and cannot get the holes to lineup due to the thickness of the plates.
Thanks
Thanks
